Handheld CIs, hardware assets, and model categories
Alan Akins
I've done a little searching but haven't really found proper guidance here. This might be more of an asset or CMDB question, as it's related to both.
After installing HAM, extended classes, etc., and there still is no mapping of any asset Model Category to a CI class for phones, mobile devices, etc. CI records created by Intune, Workspace One, Jamf, etc., all go into the Handheld Computing Devices CI Class. However, unlike computers (laptops, desktops), there is no way to have an asset record automatically created because the HHCD class is not mapped to any Model Category.
I know the only way to make a mapping is to create a new model category, because it isn't possible to edit an existing one. So the OOTB mobile-related model categories do me no good it appears. Does someone have insight as to why ServiceNow doesn't have this mapping already included/created? Are there any elegant solutions which don't require me to create a custom model category?
achin_chawla
Mega Guru
Here's a breakdown of the situation and potential solutions:
1. Out-of-the-Box (OOTB) Mapping:
ServiceNow does not currently provide OOTB mappings for the "Handheld Computing Devices" CI class to asset model categories like phones or mobile devices. The reason could be that the use cases for mobile devices can vary greatly across organizations, and ServiceNow aims to keep the platform flexible for customization rather than prescriptive in these scenarios.
2. Why OOTB Model Categories for Mobile Devices Don’t Work:
The existing OOTB model categories are not linked to the "Handheld Computing Devices" CI class. This is likely because these CI classes are often populated by integrations (e.g., Intune, Workspace One, or Jamf) and are not always managed directly within the CMDB by default.
3. Elegant Solutions Without Creating Custom Model Categories:
Unfortunately, as of now, creating a new model category and mapping it to the HHCD CI class is the best way forward if you want automatic asset record creation. However, if you'd prefer not to create new categories, consider the following approaches:
Business Rule or Script Include: Create a custom business rule or script to map incoming CIs from Intune/Workspace One/Jamf to an appropriate asset model category based on your organization's requirements.
Table Inheritance: If you expect a significant amount of customization, consider extending the model category table (cmdb_model_category) to include a new subcategory specifically for handheld devices. This avoids editing OOTB configurations directly.
Dynamic Category Assignment: Use a data lookup rule to assign categories dynamically based on specific attributes (like manufacturer, model, or CI class).
4. Long-Term Recommendation:
If this is a frequent use case for your organization, it's worth creating a custom model category and documenting this in your CMDB governance policies. While it adds a step upfront, it simplifies ongoing management and ensures consistency.
15 REPLIES 15
Certainly possible. I'm still searching around. It's not in my production instance either. On your HHD model category, can I ask what the Create and Created By are? The date at least might help me figure out at what point in time we missed some kind of update.
do you have cmdb_ci_handheld_computing OOTB?
Indeed I do have it, yes. It is not linked to any Model Category however.
yes you will need to create one.
Hello Alan,
if my answer has helped with your question, please mark my answer as accepted solution and give a thumb up.
