01-27-2025 10:52 PM
I want to extract the value of a record's choice field in a flow.
In a data pill I get the label value.
Is there a better way to do this?
01-27-2025 11:44 PM
not possible. It's a platform behavior and it will always give choice label and not choice value
07-15-2026 06:18 AM
Hi @Asha Patil,
By default, ServiceNow Flow Designer retrieves the backend Value of choice fields (e.g., 10 or new_value) rather than their user-friendly Label (e.g., New or In Progress) when you drag and drop a standard data pill.
To store the readable label instead of the backend value in a flow variable, you must use inline scripting with the getDisplayValue() method.
Here is how you can set it up in your flow:
1 - Add/Edit the "Set Flow Variables" :
- In your Flow, add or navigate to the Set Flow Variables action;
- Select your target String variable.
2 - Enable Inline Scripting, instead of dragging and dropping the field's data pill directly into the Value field:
- Click the Script icon (</> or fx) next to the variable's value field to open the inline script editor;
3 - Write the Script, use the following Javascript snippet depending on where your choice field originates:
Scenario A: Standard Choice Field on a Record (e.g., Incident State)
If your choice field is from a standard table record triggered at the beginning of the flow, use:
return fd_data.trigger.current.YOUR_FIELD_NAME.getDisplayValue();
Replace YOUR_FIELD_NAME for the technical name of your choice field.
Scenario B: Service Catalog Select Box / Choice Variable
If you are pulling a choice variable from a Service Catalog Item (RITM):
return fd_data.trigger.request_item.variables.YOUR_VARIABLE_NAME.getDisplayValue();
Replace YOUR_VARIABLE_NAME for the exact name of your catalog variable.
The platform's native data pill system evaluates choice and reference fields to their raw database values (sys_id or choice value). Writing a simple one-line script bypasses the default mapping behavior and explicitly pulls the display label.
