Life Cycle Stage Status Change using Flow Designer
Getting Business rule Error while changing Life Cycle Stage Status using flow designer. Same is working fine manually.
Error: "Error occured while updating record: Operation against file 'cmdb_ci' was aborted by Business Rule 'Validate lifecycle combination^36aa723643361110ec0553c0bcb8f28f'. Business Rule Stack:Validate lifecycle combination"
Hi @Community Alums ,
Just build exactly the same as your flow and tested. It works for me with the active BR. But the set value action in flow need to be in script, like this:
Life Cycle Stage:
Life Cycle Stage Status:
CMDB Record:
Flow Operation:
@Community Alums, Got the solution. Thanks.
