Alternative Encryption Products to GlideEncrypter
KaruppusamyN
We have Depreciate 3DES in our instance, i am trying to modify an existing script in my instance GlideEncrypter with solution provided by Knowledge Article, but the issue is the alternatives are not working for me. Kindly anyone have sample script for GlideEncrypter().encrpty(), share it with an example
Hi @KaruppusamyN ,
You cannot rely on GlideEncrypter() in your scripts after the deprecation of DES/3DES. All related code must be updated to supported alternatives using AES and the platform’s integrated cryptography tools before Zurich, or your encryption/decryption routines will fail.
ServiceNow is in the process of fully deprecating and then removing the GlideEncrypter API (which is based on Triple DES encryption), with complete removal targeted for the Zurich release in Q4 2025
Please refer the below servicenow offical docs.
GlideEncrypt Global ,
Deprecate GlideEncrypter usage of 3DES for password2 fields ,
GlideEncrypter API not permitted beginning with the Xanadu release
Bhimashankar
If my response points you in the right directions, please consider marking it as 'Helpful' & 'Correct'. Thanks!
