Flow issues- Flow not being used
10-06-2025 10:27 AM
All,
I hope that you can assist with this issue. I have created and assigned flows to my catalog items. However, when someone submits a request it is not using that flow and using a generic flow. How can I force to use the flow assigned to that item. It is causing some headache and could lead to audit concerns.
10-06-2025 08:24 PM
Hi @LATimC ,
- Navigate to Service Catalog > Catalog Definitions > Maintain Items.
- Open the catalog item that is using the wrong flow.
- Go to the Process Engine tab.
- Ensure that the Flow field has your specific flow selected.
- Crucially, ensure the "Workflow" and "Execution Plan" fields are both empty. If an entry exists in the "Workflow" field, it will take precedence over the flow in the "Flow" field.
- Navigate to Process Automation > Flow Designer.
- Open your flow.
- Click the Trigger section.
- The trigger should be set to "Service Catalog".
- Check the Trigger > Configuration and ensure it's configured to trigger for "Any" catalog item, or specifically for your catalog item if you've chosen that setting
- In your flow, check the header to see if it is Published.
- If the flow is in a draft state, click the Activate button to publish it.
- After publishing, return to the catalog item record and save it again to confirm the link between the item and the flow
- If your generic flow is an out-of-the-box workflow, check that the "Cascade Request Approval to Request Item" business rule is functioning as expected and not triggering the generic flow instead of your custom one
Thanks, GP
10-06-2025 08:38 PM
Did you associate your activated flow with your Catalog item?
