Some major Difference between Flow and Workflow.
Tushar8649
What is Workflow?
Workflow (built in the classic Workflow Editor) is the older automation tool in ServiceNow. It uses the Workflow Engine and is represented visually as a diagram with activities like approvals, tasks, timers, and scripts.
It has been used for years in areas such as:
  • Legacy Service Catalog workflows
  • Older change/request fulfillment processes
  • Older custom automations built with “activities”
What is Flow Designer?
Flow Designer is the newer, strategic automation platform in ServiceNow. It uses the Flow Engine and is built for low-code/no-code automation with reusable components like Actions and Subflows, plus stronger integration support (often via IntegrationHub spokes).
Flow Designer is widely used for:
  • New Service Catalog fulfillment (Catalog Flows)
  • Cross-application automation (HR, ITSM, CSM, SecOps, etc.)
  • Integrations (REST, SOAP, Jira, AD, Teams, Slack, etc., depending on licensing/spokes)
  • Event-driven automation and orchestration
ServiceNow recommends Flow Designer for new development in most cases.
High-level comparison table
Category Workflow (Legacy) Flow Designer (Modern)
Primary toolWorkflow EditorFlow Designer
EngineWorkflow EngineFlow Engine
ServiceNow directionMaintenance/legacy for many use casesStrategic/default for new automation
Ease of useMore technical; older UIModern low-code UX, data pills, guided building
ReusabilitySubworkflows exist but less modularStrong reusability with Actions and Subflows
IntegrationsPossible, often script-heavyStrong integration support via IntegrationHub actions/spokes
Debugging/troubleshootingWorkflow context + logsRich Execution Details, step-by-step inputs/outputs
VersioningSupported (workflow versions)Strong versioning and easier iteration/activation
Trigger typesOften started via BR/UI action/scriptMany triggers: record, schedule, inbound/API, event (varies by setup)
ExtensibilityCustom Activities (older model)Custom Actions/Subflows (preferred model)
ScriptingCommon for complex logicPossible, but more “configuration-first”
DeploymentUpdate setsUpdate sets / App scope-friendly packaging
Detailed differences (in practical terms)
1) User experience & development approach
Workflow
  • Built in the Workflow Editor (older canvas UI).
  • Activities are often more “engine-specific” and can require more platform knowledge.
  • Complex logic frequently leads to scripts inside workflow activities.
Flow Designer
  • Built in Flow Designer (modern interface).
  • Uses Data Pills (drag-and-drop outputs from previous steps).
  • Encourages a cleaner separation:
    • Flow = orchestration (the “recipe”)
    • Action = reusable step
    • Subflow = reusable mini-process
Result: Flow Designer is typically easier to build, read, reuse, and maintain.
2) Reusability and standardization
Workflow
  • Supports subworkflows, but reusability is generally less modular and less standardized across teams.
  • Custom logic often becomes “embedded” inside a workflow.
Flow Designer
  • Designed for reusability:
    • Actions can be reused across many flows
    • Subflows can be called by multiple flows, catalog items, or other processes
  • Supports better standardization across an organization (shared actions like “Create Task”, “Notify Group”, “Call REST API”, etc.)
3) Integrations and orchestration
Workflow
  • Integrations are possible, but often require:
    • Script activities
    • Custom code
    • Older orchestration patterns
Flow Designer
  • Integrations are a major strength:
    • Many integrations are available as spokes (e.g., REST, Microsoft Teams, Slack, Jira, AD, etc.)
    • Steps often require little or no script
  • Note: Some integration capabilities require IntegrationHub licensing (depends on the spoke/action).
4) Troubleshooting and operational support
Workflow
  • Troubleshooting typically uses:
    • Workflow Context record
    • Workflow Log
  • Logs can be less intuitive for non-developers.
Flow Designer
  • Provides detailed, step-by-step Execution Details:
    • Inputs and outputs per step
    • Clear error messages
    • Easier “what happened and why” visibility
Result: Flow Designer generally reduces time to troubleshoot and support automations.
5) Triggers and event-driven automation
Workflow
  • Often started manually or by something like:
    • Business Rule calling “Start workflow”
    • UI Action
    • Scripted start conditions
  • Works well, but the pattern is older and more developer-driven.
Flow Designer
  • Supports modern trigger patterns such as:
    • Record created/updated triggers
    • Scheduled triggers
    • API/invocation (depending on design)
    • Potential event-driven patterns (depending on implementation)
6) Customization model (Activities vs Actions)
Workflow
  • Extensibility is often done via custom activities.
  • Custom activities are an older development approach and can be harder to maintain.
Flow Designer
  • Extensibility is done via:
    • Custom Actions
    • Subflows
    • Optional scripted steps where necessary
      This is the newer, recommended extensibility model.
7) Service Catalog usage (common real-world difference)
Workflow (Legacy Catalog)
  • Many older catalog items use Catalog Workflows (Workflow Editor).
  • Still commonly found in long-running instances.
Flow Designer (Modern Catalog)
  • Newer implementations use Catalog Flows.
  • Reusable fulfillment logic is easier with subflows/actions.
Recommendations / Best Practice Guidance
Use Flow Designer when:
  • You are building new automations
  • You need reusability (subflows/actions)
  • You want better debugging/monitoring
  • You are integrating with external systems (especially with IntegrationHub)
  • You want automation that’s easier for admins (not just developers) to maintain
Use Workflow when:
  • You are maintaining existing legacy workflows
  • You have out-of-the-box processes still heavily based on Workflow in your environment
  • Migration effort is not currently justified (e.g., stable process with low change rate)
General guidance: For most new development, prefer Flow Designer. Keep Workflow for legacy processes until you have a planned modernization/migration.
Migration note (Workflow → Flow Designer)
ServiceNow commonly modernizes by:
  1. Identifying high-value workflows to convert (high change rate, high support cost, integration-heavy).
  2. Rebuilding logic as:
    • One or more Flows (or Catalog Flows)
    • Shared Subflows for common steps
    • Shared Actions for repeated tasks/integrations
  3. Running parallel testing before retiring the legacy workflow.
Migration is usually a rebuild, not a simple “one-click conversion,” because the engines and constructs differ.
Summary
  • Workflow is the legacy automation engine: powerful, proven, but older and less modular.
  • Flow Designer is the modern automation platform: easier, more reusable, better integrated, and ServiceNow’s recommended direction for new automation.
0 REPLIES 0
