Glideajax script include
MohdF
Hi all,
When I am trying to auto populate caller's email, location and manager in the incident after changing the caller, it is auto populating the email and manager's field but not the location field, I am using client scripts and script include for this
This is my client script
	var caller_details = g_form.getValue('caller_id');
	var ga = new GlideAjax('AutoPopulate_CallerInfo');
	ga.addParam('sysparm_name', 'getCallerInfo');
	ga.addParam('sysparm_value', caller_details);
	ga.getXML(callback);
	function callback(response){
		var test = answer.split(',');
		g_form.setValue('u_email_id', test[0]);
		g_form.setValue('u_caller_s_location', test[1]);
		g_form.setValue('u_caller_s_manager', test[2]);
and this is my script include
var AutoPopulate_CallerInfo = Class.create();
AutoPopulate_CallerInfo.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getCallerInfo: function() {
        var sysIdofcaller = this.getParameter('sysparm_value');
        var x = new GlideRecord('sys_user');
        x.addQuery('sys_id', sysIdofcaller);
        x.query();
        if (x.next()) {
            return x.email+','+x.location+','+x.manager;
        return '';
    type: 'AutoPopulate_CallerInfo'
 Please help! anyone!
@MohdF ,
what type of field you have used for Callers location ? and are you referencing it to cmn_location table or not ?
please put an alert and check what you are getting ?
Please mark this comment as Correct Answer/Helpful if it helped you.
Swathi Sarang
Swathi Sarang
12 REPLIES 12
Pratima Kalamka
swathisarang98
Hi @MohdF ,
I tried your code in my PDI all three field are getting populated, could you please try with a user record where  all three values are filled like EMAIL,manager and location,
Swathi Sarang
MohdF
I don't why its not working I am using the users who have all the details email, location and mail
Please refer to the image attached.
Hi @MohdF,
Please type cache.do in navigator. Also please try this below code:
x.addQuery('sys_id', '62826bf03710200044e0bfc8bcbe5df1');
x.query();
if (x.next()) {
    gs.info(x.getValue('email') + ',' + x.getValue('location') + ',' + x.getValue('manager'));
Please user x.getValue instead of .email hope this will work out.
Please accept my solution if it works for you and thumps up.
Jitendra
Please accept my solution if it works for and thumps up.
@MohdF ,
Swathi Sarang
Swathi Sarang
