How do Reference Qualifier on variable work on Target Record once the Record Producer?
Swathi P
Hello Team,
I have reference qualifier available on Record Producer . I want it work on Target Record if the user wants to edit the variable from Target Record How can i achieve this
13 REPLIES 13
Swathi P
My Reference qualifier is working fine on Record Producer but not once the Record Producer is submitted. I am trying open the submitted record from Portal
@Swathi P
so did you debug if script include is getting called when 2nd variable is being clicked with lookup icon?
add logs and see what value came in? if value is getting passed correctly in script include.
you didn't share complete script include.
Swathi P
Yes it is getting inside script include This is my Script include
getGroupMembers: function(producerGr) {
        var transactionType, itemType, gcurrency, gAmount, gSGDAmount, hCurrency, hAmount, hSGDAmount, requestor;
        transactionType = producerGr.u_type_of_submission,
        itemType = producerGr.type_of_request;
        gcurrency = producerGr.u_gift_currency;
        gAmount = producerGr.u_average_amount;
        gSGDAmount = producerGr.u_average_amount_sgd;
        hCurrency = producerGr.u_hosp_currency;
        hAmount = producerGr.u_hosp_average_amount_1;
        hSGDAmount = producerGr.u_hosp_average_amount;
        requestor =  producerGr.opened_by;
        var wf_amt = producerGr.workflow_amount;
        gs.info("TEST THE qUALIFIER");
        gs.info('workflow_amt ' + wf_amt);
        var answer = 'sys_idIN';
        var userList = [];
        var approverGroup = this.getGroup(transactionType, itemType, gcurrency, gAmount, gSGDAmount, hCurrency, hAmount, hSGDAmount, requestor);
        var groupMemberGr = new GlideRecord('sys_user_grmember');
        groupMemberGr.addQuery('group', approverGroup);
        groupMemberGr.query();
        while (groupMemberGr.next()) {
            userList.push(groupMemberGr.user.toString());
        answer += userList.join(',');
        return answer;
Swathi P
Actually It is not getting inside the script include Is it a problem since i am calling trying it from Portal
