how to call system property in catalog client script.
Devaceis
Hello Developers,
Requirement - I have to create a client script for in some catalog item On hold state should be there and for other catalog item on hold state should not be there.
Condition- I have to create a system property , in the system property there is a field as Value. in value filed I have to pass catalog item sys_id. whichever sys_id is present in System property VALUE field for that on hold should be for other item on hold should be not there.
What I did to get to done this requirement -
I have created - system property. script include , client script.
system property -
Script Include -
Client Script-
What Problem I am getting -
problem is that for every catalog item On HOLD state is coming. whenever in system property only two item sys_id
I have Passed , so idealy  only for two catalog item On hold state should be come.
So please help me to solve this problem.
Thanks and regards.
manjusha_
@Devaceis
Use below client script and script include-
Client Script-
function onLoad() {
//alert("hell0");
var item= g_form.getValue('cat_item');
var grAjax = new GlideAjax('GetCatalogId');
grAjax.addParam('sysparm_name','getProperty');
grAjax.addParam('sysparm_cat_item',item);
grAjax.getXML(getDemo);
function getDemo(response){
alert("hellresult"+item);
alert("SCRIPTRESULT"+answer);
if(answer=='true'){
g_form.addOption('state','5','On Hold Reason');
// g_form.removeOption();
else{
g_form.removeOption('state','5')
Script include- client callable
var GetCatalogId = Class.create();
GetCatalogId.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getProperty: function() {
var retResult = false;
var i = 0;
var item = this.getParameter('sysparm_cat_item');
var cat_property = gs.getProperty('test_cat_item');
var result = cat_property.split(',');
for (i = 0; i < result.length; i++) {
if (result[i] == item) {
retResult = true;
return retResult ;
if (i == ((result.length) - 1)) {
return retResult;
type: 'GetCatalogId'
If my answer solved your issue, please mark my answer as ✅Correct & 👍Helpful based on the Impact
Manjusha Bangale
manjusha_
@Devaceis
Client Script-
function onLoad() {
//alert("hell0");
if(answer=='true'){
else{
var i = 0;
retResult = true;
return retResult ;
return retResult;
Manjusha Bangale
Devaceis
@manjusha_
Thanks , It working Now.
