Playbook is keep on loading
01-07-2026 12:29 AM
I have custom table (X) and custom playbook created for table X. It is working fine in Yokohama release. We have upgraded recently to Zurich patch 4. We are actually creating a record using playbook record generator only. After upgrade, if we open the playbook and fill the details in record generator step and click on continue, its keep on loading. No record generated at the backend as well as it is not moving to further step in playbook.
Please help us out ASAP if someone across this issue.
Thanks in advance!
01-08-2026 06:12 AM
Could you please check from your side what is the latest version you people using?
01-07-2026 01:38 AM
did you check those 2 links I shared and tried that approach?
01-07-2026 01:48 AM
I am able to open this one "Playbook record generator loading infinitely " and not another one.
I checked the script configuration and It is correct. But its still loading. Issue not sorted.
01-08-2026 05:10 AM
03-31-2026 02:27 AM
Hope you are doing good.
