Using Flow Designer to Generate a PDF and attach it to a record
Alan11Robin
I am trying to generate a PDF based on variables on a record and attach the PDF to the record.
I had this working perfectly in my personal developer's instance using a UI action.
Now, I am trying to do so using Flow Designer and I am having no success.
Could someone give me some advice or guidance, please?
Thank you.
13 REPLIES 13
It still isn't functioning and I have no idea why.
Can you share screenshots or provide more detail as to the issue / error you are seeing?
There is no error.  The issue is, no PDF is being generated when it should and I don't know why.  I followed all your instructions.
Joselin
when saving the action it does not let me get the following error marked in green
