Reference qualifier with cilent script
07-29-2025 03:03 AM
I have cost center field (select lookup with reference to cost center table) and project category field (selectbox with manually entered values).
Cost center based on project category.
Example: scent (project category) has 3 cost center. It should only visible instead of showing the whole list.
I need reference qualifier with client script for this.
07-29-2025 05:56 AM
There is no relationship between project category and cost center.
07-29-2025 06:02 AM
Did you get a chance to check my above response?
07-29-2025 08:43 AM
Hey @AnnamalaiS ,
You’re saying there’s no relationship between the project category and the cost center, but then how do you know that the project category has three cost centers? If you can clarify this, it will be easier to provide a solution.
07-29-2025 08:55 AM
user shared a list of cost centers for each category.
07-29-2025 08:58 AM
Can you please confirm which table stores the project category, and check if there is any mapping with the cost center?
