Need to combine two list collector values in flow designer using custom action servicenow
anushadande1793
Hi
There are two list collector fields on the from (service catalog form) and we need to combine the values selected for those two list collector values in flow designer. I have written one custom script with the below code by taking inputs as list collector fields with the type 'string' and given a try with  output type as 'array-string/string' but still it is not working. Can someone helps on this please
var teamselected = inputs.teammember.toString();
 var teamselectedsplit =teamselected.split(',')
var scrumselected =inputs.scrummaster.toString();
 var scrumsplitedusers =scrumselected.split(',')
var au = new ArrayUtil();
 var finallist = GlideArrayUtil.union(teamselectedsplit,scrumsplitedusers);
 outputs.userssplitedafter =finallist.toString();
Anusha
@anushadande1793 Create a flow variable and combine both value in set variable so you can use flow variable with having all value from both list collectors,hope this helps you.
Hi Abhay,
Thanks for the Reply.
Can you please help me how to combine both values using flow variables.
Anusha
use this sample code with changing variables
// Initialize an empty array for the combined list
var combinedList = [];
// Add all elements from the first list collector, if present
combinedList = combinedList.concat(inputs.listCollector1 || []);
// Add only unique elements from the second list collector
(inputs.listCollector2 || []).forEach(function(item) {
    if (combinedList.indexOf(item) === -1) {
        combinedList.push(item);
// Return the combined array to be assigned to the flow variable
combinedList;
Hope this will help.
