No technical background to become a ServiceNow developer?
NandanO
Is it possible for someone with no technical background to become a ServiceNow developer? If yes, what is the realistic time frame to learn it?
2 ACCEPTED SOLUTIONS
Dr Atul - LNG
Hi @NandanO
As you mentioned that you come from a non-technical background, I would say it might be challenging, but it is definitely not impossible. I have seen many people build successful careers in ServiceNow coming from non-technical backgrounds.
The timeline is difficult to predict because it depends on how much effort you put in, how consistently you learn, and how dedicated you are to preparing and building your skills.
With the right mindset, continuous learning, and hands-on practice, transitioning into ServiceNow is absolutely achievable.
Here are a few tips:
  1. Follow this master playlist to strengthen your JavaScript skills specifically for the ServiceNow platform.
https://youtu.be/62Nabpb94Jw?si=FqBwRN2B8C71aYHr
  1. Spend at least 1–2 hours daily on the ServiceNow Community. Observe the kinds of technical questions being asked and how experienced members respond. You’ll learn a lot passively this way—and I highly encourage you to start answering questions as well. Explaining concepts to others will improve your technical thinking and deepen your understanding.
  1. Explore the free courses available on the ServiceNow Developer Site. These are practical and focused, and will help you apply your knowledge directly on the platform.
  2. https://developer.servicenow.com/dev.do#!/learn/learning-plans/yokohama/citizen_developer
  3. https://developer.servicenow.com/dev.do#!/learn/learning-plans/yokohama/servicenow_application_devel...
JavaScript on the Now Platform enables you to create more complex logic and user experiences. This video series introduces you to the JavaScript language specifically tailored to its use in the Now Platform. Lab exercises in this series give you experience from basic syntax to flow control to ...
Tanushree Maiti
Hi @NandanO
If you are from coding background (any technology , specifically java script, java) , within very short span of  time , you will learn scripting .
If you are interested to Servicenow, I will suggest you to follow structured path.
1. First complete CSA
2. Then go through CAD with scripting.
CSA Tips:
CAD Tips:
1. Go Through the course content till your concept is clear.
Certified Application Developer (CAD) Learning Path
2.  Certified Application Developer (CAD) Exam Blueprint for syllabus
3. Practice in your Personal Developer Instance (PDI)
  • Practice lots of mock question with Correct Answer
  • Practice from ServiceNow university provided practice : https://account.measureup.com/servicenow-university
  • If anything left or you are struggling with answering practice test, Revisit the course content.
  • Once you are confident ,  Schedule the exam and Go for it.
Note: Once registered, you have 90 days to schedule and complete your exam.
Refer: https://nowlearning.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0011554
For Scripting:
Go through these course and other resources. from script itself, you will find the usecases.
1. Introduction to Scripting in ServiceNow
2. Scripting in ServiceNow Fundamentals
3. Refer syllabus for scripting : KB0012764 Scripting in ServiceNow Fundamentals (SSNF) Syllabus
4. Go through once related youtube videos
https://www.youtube.com/watch?v=Ccxb4UJKF9c
https://www.youtube.com/watch?v=WLNQinTkLfQ
5. Practice in  your Personal Developer Instance (PDI).
6.Client Script in ServiceNow With some use case.
7.https://www.learnnowlab.com/Business-Rules/
8.want some use cases for Client Script, Business rule , Script Include , and Glide Ajax
9.Mastering Client Scripts in ServiceNow – A Practical YouTube Playlist for Real-World Scenarios
10.Script Action: A Practical Example!
etc.
Tanushree Maiti
Tanushree Maiti
Hi @NandanO
CSA Tips:
CAD Tips:
For Scripting:
etc.
Tanushree Maiti
