Using questions for automation in Creator Studio - Decision Branches
patrickscho
Dears,
i was playing with the latest Xanadu Release Patch 1 and tried to configure a simple decision tree based on a dropdown value.
Unfortunately still the question variable is not selectable and as a "Creator" you basically have 0 possibility to automate the flow.
Is there any way we can use the forms input as decision branches without "pro adjustments" in studio to make the variable a real table field?
Thanks for your advice!
0 REPLIES 0
