02-17-2025 11:41 PM - edited 02-18-2025 01:58 AM
I have a requirement to set the dropdown field value on the case based on the variable value select on the form via flow designer
Variable on the form is of multiplechoice type:
eg: if user selects 1st option from the form the field value on the case will be set as allowed. Office type field is a choice type field. If the user selects 2nd option then office type field value will be set as review pending.
02-18-2025 12:50 AM
you can use inline f(x) script and use if else and determine the value
02-18-2025 01:02 AM
Hi @Shivam32 ,
"Try using the fd_data object and use the dot notation (fd_data.). This will display multiple options to choose from. If you have already retrieved variables using the 'Get Catalog Variables' action, you can use them as shown below to fetch a particular variable value.
In this example, I am sending the obj to the event parameter parm2, where the remarks are being fetched from the 'Get Catalog Variables' action used in step 2. When you type fd_data., you will see multiple options to select from."
Kindly mark as correct/helpful if solves your issue.
Best Regards,
Pooja
