Add Endpoint and Payload to Flow Designer
Kri
Can we able to add direct Endpoint and Payload to the Flow Designer
Ankur Bawiskar
@Kri
yes it's possible, but not recommended as the end point might change from instance to instance
It will vary for DEV, PROD.
I will recommend to store that in system property so that you can simply update that after migration and you need not touch the flow
@Kri
Hope you are doing good.
💡 If my response helped, please mark it as correct ✔️ and close the thread 🔒 — this helps future readers find the solution faster! 🙏
