Advanced Reference Qualifier Based-On Current Variable
01-22-2018 08:45 AM
Need help setting-up an advanced reference qualifier that uses the 'u_term_code' field from the *Term drop-down as a dependency and returns a list of courses that share the value.
javascript: u_term_code = current.variables.u_term_code;
Above, is the code I currently have.
01-23-2018 11:37 AM
Can you post the variable dictionary as well alongwith your current code.
01-23-2018 11:57 AM
I apologize, I thought that was what I had posted, above?
01-23-2018 01:31 PM
You posted screenshot of the field in table BSU terms.
I was asking about the field Term on the catalog. I need to see how you are pull data list in that field. So I will need the variable configuration.
01-23-2018 01:38 PM
01-23-2018 01:40 PM
Not course. the term variable you have on form.
