API call through script include using client script
chrisn_
Mega Guru
Hello everyone,
I am using an onchange client script to pass 1 variable of data to a script include which will fire off a REST message to retrieve 4 other data points. My end goal is to take these 4 data points and enter them on the same form that started the process. Has anyone else had success doing this? Can I set the fields directly from the script include or do I need to somehow pass the data points back to the client script to set them? Currently I am able to call my script include successfully, but my script include is failing.
This is my client script. Which appears to be working as hoped.
var ga = new GlideAjax('x_unoci_rapid_retu.Rapid Return Course Call');
ga.addParam('sysparm_name', 'RRCall');
ga.addParam('sysparm_x_unoci_rapid_retu_course_code', "");
alert("hello");
ga.getXML(RRCallParse);
alert(response);
function RRCallParse(response) {
alert(answer); }
This is my script include which is failing.
var RRcourseinfo = Class.create();
RRCourseCall.prototype = Object.extendsObject(global.AbstractAjaxProcessor,{
RRCall: function() {
var input = this.getParameter('sysparm_x_unoci_rapid_retu_course_code');
var responseBody;
var requestBody;
var r;
var httpstatus;
try {
r = new sn_ws.RESTMessageV2('x_unoci_rapid_retu.EEE course information ', 'Default GET');
r.setStringParameterNoEscape('Course Code', input);
var response = r.execute();
var httpStatus = response.getStatusCode();
catch(ex) {
var message = ex.message;
}finally {
requestBody = r ? r.getRequestBody():null;
var parsedResponse = JSON.parse(responseBody);
current.x_unoci_rapid_retu_quarter = parsedResponse.qtrName;
current.x_unoci_rapid_retu_course_name = parsedResponse.name;
current.x_unoci_rapid_retu_total_students = parsedResponse.numStudents;
current.x_unoci_rapid_retu_quartershortcut = parsedResponse.qtr;
current.update();
type: 'Rapid Return Course Call'
The error I am getting is:
org.mozilla.javascript.EcmaError: "RRCourseCall" is not defined.
Caused by error in sys_script_include.67e8d3addb007f00712f389f9d961988.script at line 2
1: var RRcourseinfo = Class.create();
==> 2: RRCourseCall.prototype = Object.extendsObject(global.AbstractAjaxProcessor,{
3: RRCall: function() {
4: var input = this.getParameter('sysparm_x_unoci_rapid_retu_course_code');
5: var responseBody;
I have have tried something different, but I'm still not having any luck. I tried packaging the returned information like this to be moved to the client script.
RRcourseinfo.prototype = Object.extendsObject(global.AbstractAjaxProcessor,{
var responseBody;
var requestBody;
var r;
var httpstatus;
try {
catch(ex) {
finally {
var packagedXML = this.newItem("RRCallXMLResponse");
packagedXML.setAttribute("x_unoci_rapid_retu_quarter", parsedResponse.qtrName);
packagedXML.setAttribute("x_unoci_rapid_retu_course_name", parsedResponse.name);
packagedXML.setAttribute("x_unoci_rapid_retu_total_students", parsedResponse.numStudents);
packagedXML.setAttribute("x_unoci_rapid_retu_quartershortcut", parsedResponse.qtr);
then alerting myself as a test this way in the client script.
if (isLoading || newValue == '') { return; }
console.log("GlideAjax: x_unoci_rapid_retu.Rapid Return Course Call beginning"); // log beginning of function
console.log("GlideAjax: Rapid Return Course Call, finished addParam");
//alert("hello");
console.log("GlideAjax: Rapid Return Course Call, getXML call finished");
var answer = response.responseXML.documentElement.getElementsByTagName("RRCallXMLResponse");
console.log("GlideAjax: Rapid Return Course Call -> RRCallParse, answer is: " + answer);
console.log("GlideAjax: Rapid Return Course Call -> RRCallParse length: " + answer.length);
console.log("GlideAjax: x_unoci_rapid_retu.Rapid Return Course Call finished");
Unfortunately I am not getting anything in the sys log. The console is telling me nothing useful either. It's triggering, but not getting anywhere.
