ATF, Not setting some field values
iqbalansari
Good morning Friends,
I have created a test having a step of set field values. Inside that I am setting 3 field values for a Story record.   The test ran fine and the results shows that it set the field values, however when I open the record the value is not updated there, here is the test results and screenshot of record after test ran.
I you see the record, It successfully changing the Percent Complete, but not changing the order and description.
Any idea? What I am missing here?
Results
Screen shot of the record:
12 REPLIES 12
I did few tests and it works fine when using comma notation. I have Istanbul patch 5. I would recommend more tests with commas, this should work.
iqbalansari
Will try that.
Muhammad
Other problem I am having is, I am not able to find screenshots, while it say " See the screenshot"
