Auto Apporve flow designer
Roxi1
We want to add the functionality to auto approve the approvals if the approver is same as "requested for". and this has to be implemented in flow designer. we have the action to "ask for approvals" from there we will get the approvals attached to the submitted requested items. after that we have to check if the requested for is same as manager(a variable in catalog item) then the attached approvals has to auto approve. Can some one please help me what needs to be done.
By updating the reference of course. 😀
Probably the reference no longer exist, or has a different number if you have added/removed actions.
So the text that reads:  fd_data._20_get_catalog_variables... need to be updated to the correct action number.
Roxi1
ok, and what is this error which is not allowing to activate the flow after making changes. how can i fix it
Roxi1
Hello OlaN,
after making changes i got these error and not allowing me to activate
Error:
attempting to use undefined input = 'catalog_variable' from f4037a1adbe689949ee932f6f49619a8
Maybe you should rewrite the inline script from start?
Roxi1
we did not written any inline script, we just used id activity to validate the approvers
