Auto Apporve flow designer
Roxi1
We want to add the functionality to auto approve the approvals if the approver is same as "requested for". and this has to be implemented in flow designer. we have the action to "ask for approvals" from there we will get the approvals attached to the submitted requested items. after that we have to check if the requested for is same as manager(a variable in catalog item) then the attached approvals has to auto approve. Can some one please help me what needs to be done.
By updating the reference of course. 😀
Probably the reference no longer exist, or has a different number if you have added/removed actions.
So the text that reads:  fd_data._20_get_catalog_variables... need to be updated to the correct action number.
The inline script I'm referring to, is the one where you have scripted to use fd_data.... in the action.
It might not be a script, but a data pill that is referencing the wrong action.
There is not enough details for me to help you any further with this additional error.
