08-30-2017 11:59 AM
Hi All -
I am looking for the best way to create/populate a custom field on the User form that I will name MGR Email, and it would do the following:
- prefix with a static value of: mgr
- then grab the value in the Location field for that user (Location on sys_user)
- then suffix it with the email domain: @xyz.com
So if I had a user record open and that user's location value was 123, then this MGR Email field would be populated for that user as: mgr123@xyz.com
If the user's location was empty - then it should result in no value populated within this MGR Email field for that user.
Thank you!!
09-13-2017 01:35 PM
Did you try this ?
This should be a before business rule with insert and update check boxes checked. Below is the script.
if (current.location!='')
current.your_mgr_email_field = 'mgr'+current.location.name+'@xyz.com';
else
current.your_mgr_email_field = '';
09-14-2017 08:11 AM
Hi Sanjiv -
Realized I needed to do a mass update for all existing users for the rule to take effect. I was able to get this working. Thanks so much for your help!
09-13-2017 02:24 PM
