05-29-2019 06:57 AM
Hi, i have an issue in the below condition.
In Incident table there is a list field = u_customers and in the Change request table there is = u_customers_impacted list column.
I want to compare if the list of customers in Incident table is available in Change request customer list and what are found i want to remove them from the incident list. From the below script, what ever is found is getting updated but when i use for updating only not found values, it is updating multiple times the same found value.
if (cust_arr_inc[i].indexOf(cust_arr_cr[j])>= 0) - this condition is updating the found values
but i want to do something like if (cust_arr_inc[i].indexOf(cust_arr_cr[j])<= 0) to update only not found values and it is repeating the customer names multiple times. Below is the complete script - please suggest.
var cust_found_arr = [];
var match = false;
var i = 0;
var j = 0;
gr.addQuery('number', 'INC0170752');
while (gr.next()) {
var changeReq = new GlideRecord('change_request');
changeReq.addQuery('cmdb_ci', gr.cmdb_ci);
changeReq.query();
while (changeReq.next()) {
gs.print('the CR numbers matched is ' + changeReq.number);
var cust_arr_inc = [];
cust_arr_inc = gr.u_customers.toString().split(',');
gs.print('the Inc customers are ' + cust_arr_inc + gr.number);
var cust_arr_cr = [];
cust_arr_cr = changeReq.u_customers_impacted.toString().split(',');
gs.print('the CR customers are ' + cust_arr_cr + gr.number);
for (i = 0; i < cust_arr_inc.length; i++) {
for (j = 0; j < cust_arr_cr.length; j++) {
if (cust_arr_inc[i].indexOf(cust_arr_cr[j]) >= 0) {
cust_found_arr.push(cust_arr_inc[i]);
gs.print('The matched Companies are :' + cust_found_arr + ' - ' + gr.number);
if (cust_found_arr[0].length > 0) {
gr.setValue('u_customers', '');
gr.setValue('u_customers', cust_found_arr.toString());
gs.print('The Final Customer names are ' + gr.u_customers);
05-29-2019 08:12 AM
// Try this code
while (gr.next()) {
gs.print('the Inc customers are ' + cust_arr_inc.toString() + ' for ' + gr.number);
changeReq.query();
var current_cr_cust = changeReq.u_customers_impacted.toString().split(',');
gs.print('the CR customers are ' + current_cr_cust.toString() + " for " + changeReq.number);
cust_arr_cr.concat(current_cr_cust); // collect into the array
var arrayUtil = new ArrayUtil();
gs.print("Not found Inc companies = " + arrayUtil.diff(cust_arr_inc, cust_arr_cr).toString());
Vinod Kumar Kachineni
Community Rising Star 2022
05-29-2019 07:49 AM
Yes that is exactly what i want
05-29-2019 08:12 AM
// Try this code
while (gr.next()) {
changeReq.query();
05-29-2019 08:21 AM
Thanks, this actually shows all the missing ID's in both CR and Inc. I want to extract only Incident.
05-29-2019 08:28 AM
Do you have sys_ids for incident companies and ALL CR companies for testing.
05-29-2019 08:33 AM
Sure -
Incident Company Sys ID's -
ff33c9b2db9a6b409afd309e7c9619a3,2db67f3fdbe31b009afd309e7c961934
CR Company Sys IDs -
f9b67f3fdbe31b009afd309e7c96197a,ff33c9b2db9a6b409afd309e7c9619a3
Incident sys ID for edb8f1b3db517700b90b7b6b8c9619cb
CR SYS ID for fa6ccbf0dbddb7809afd309e7c9619ec
Thanks for supporting
