BR - Script does not execute "DOES NOT CONTAIN"
Manikandan Subr
Hi, i have an issue in the below condition.
In Incident table there is a list field = u_customers and in the Change request table there is = u_customers_impacted list column.
I want to compare if the list of customers in Incident table is available in Change request customer list and what are found i want to remove them from the incident list. From the below script, what ever is found is getting updated but when i use for updating only not found values, it is updating multiple times the same found value.
if (cust_arr_inc[i].indexOf(cust_arr_cr[j])>= 0)  - this condition is updating the found values
but i want to do something like if (cust_arr_inc[i].indexOf(cust_arr_cr[j])<= 0) to update only not found values and it is repeating the customer names multiple times. Below is the complete script - please suggest.
var cust_found_arr = [];
var match = false;
var i = 0;
var j = 0;
gr.addQuery('number', 'INC0170752');
while (gr.next()) {
    var changeReq = new GlideRecord('change_request');
    changeReq.addQuery('cmdb_ci', gr.cmdb_ci);
    changeReq.query();
    while (changeReq.next()) {
        gs.print('the CR numbers matched is ' + changeReq.number);
        var cust_arr_inc = [];
        cust_arr_inc = gr.u_customers.toString().split(',');
        gs.print('the Inc customers are ' + cust_arr_inc + gr.number);
        var cust_arr_cr = [];
        cust_arr_cr = changeReq.u_customers_impacted.toString().split(',');
        gs.print('the CR customers are ' + cust_arr_cr + gr.number);
        for (i = 0; i < cust_arr_inc.length; i++) {
            for (j = 0; j < cust_arr_cr.length; j++) {
                if (cust_arr_inc[i].indexOf(cust_arr_cr[j]) >= 0) {
                    cust_found_arr.push(cust_arr_inc[i]);
                    gs.print('The matched Companies are :' + cust_found_arr + ' - ' + gr.number);
if (cust_found_arr[0].length > 0) {
    gr.setValue('u_customers', '');
    gr.setValue('u_customers', cust_found_arr.toString());
    gs.print('The Final Customer names are ' + gr.u_customers);
// Try this code
while (gr.next()) {
gs.print('the Inc customers are ' + cust_arr_inc.toString() + ' for ' + gr.number);
changeReq.query();
var current_cr_cust = changeReq.u_customers_impacted.toString().split(',');
gs.print('the CR customers are ' + current_cr_cust.toString() + " for " + changeReq.number);
cust_arr_cr.concat(current_cr_cust); // collect into the array
var arrayUtil = new ArrayUtil();
gs.print("Not found Inc companies = " + arrayUtil.diff(cust_arr_inc, cust_arr_cr).toString());
Please mark Correct and click the Thumb up if my answer helps you resolve your issue. Thanks!
Vinod Kumar Kachineni
Community Rising Star 2022
18 REPLIES 18
Sorry Formatting issue.
Sure -
Incident Company Sys ID's -
ff33c9b2db9a6b409afd309e7c9619a3,2db67f3fdbe31b009afd309e7c961934
CR Company Sys IDs -
f9b67f3fdbe31b009afd309e7c96197a,ff33c9b2db9a6b409afd309e7c9619a3
Incident sys ID for edb8f1b3db517700b90b7b6b8c9619cb
CR SYS ID for fa6ccbf0dbddb7809afd309e7c9619ec
Thanks for supporting
What is your expected result? What company sys ids are you expecting?
Run the below as a background script.
var inc = ['ff33c9b2db9a6b409afd309e7c9619a3','2db67f3fdbe31b009afd309e7c961934'];
var cr = ['f9b67f3fdbe31b009afd309e7c96197a','ff33c9b2db9a6b409afd309e7c9619a3'];
gs.print('CR does not contain these INC companies ' + arrayUtil.diff(inc, cr));
*** Script: CR does not contain these INC companies 2db67f3fdbe31b009afd309e7c961934
// You will still have to set the values and call update
gr.setValue('u_customers', arrayUtil.diff(inc, cr));
gr.update();
This is working when I give specific sys_id’s, but will it work when I use this on a table -> field?
On what table is the BR?
When does it run?
Screenshots please
I am trying to run this on Incident table. This BR is “Before”, Insert/Update. At the moment I am testing this script in Scripts -Background
