Can not see "Save flow as template" in flow designer
‎06-01-2022 05:23 PM
- 8,809 Views
‎04-23-2024 05:23 AM
I had proceeded further without performing that task and i did completed the course and the instance is also expired cannot check now. never mind but if anyone faces the same issue maybe they will find your post helpful. Thank you!
‎04-29-2024 02:01 PM
I've noticed that when I first started the Flow Designer: Create a Flow course my instance initially had access to App Engine Studio, but after it hibernated the first time, I now only have pieces of the App Engine. I also cannot see the "Save Flow as template" option.
‎04-29-2024 09:33 PM - edited ‎04-30-2024 05:36 AM
Hi @JNSpencer, try the above solutions it it works well and good, otherwise you can skip the steps in course and still you will be eligible to receive completion badge reward, the good thing is that at least you won't stuck there.
‎04-30-2024 06:04 AM
You can always try re-installing App Engine studio and see if that helps.
‎04-30-2024 03:38 AM
Also sitting with the same issue ..
