Difference between setVisible and setDisplay
dekici3925
Hello ServiceNow community!
Can you please explain me the difference between setVisible and setDisplay on g_form?
Raju
iekosmadakis
Hello @dekici3925 !
g_form.setVisible() and g_form.setDisplay() are both used to hide or show fields on a form, but they differ in how they affect the layout.
  • g_form.setVisible() not only hides the specified field but also removes its space from the form layout, resulting in a cleaner and more compact appearance. This is useful when you want to dynamically adjust the form without leaving empty gaps.
  • g_form.setDisplay() hides the field but retains the space it occupies, which can result in blank areas on the form. This can be intentional if preserving layout structure is important, but generally, setVisible() is preferred when optimizing form appearance.
Please consider marking my answer as helpful and accepting it as the solution if it assisted you in any way.
SanjanaK
g_form.setVisible() keeps the space after hiding the field and g_form.setDisplay() hides the field and also removes the space which was occupied by it.
Hope the answer helps!
Happy Learning!
sandeep1708
Feature                  setVisible()                                                  setDisplay()
Hides Field?            ✅ Yes                                                      ✅ Yes
Space taken?          ✅ Yes (blank space shown)                   ❌ No (completely removed)
Use Case                 When hiding but keeping layout            When removing field entirely
If my answer helped you in any way, please consider marking it as helpful and accepting it as the solution
