Display 'true' not working on lookup for reference fields
sd2097
Hi all,
There's a strange issue I am facing currently. There is a custom table in the scoped application, and inside that, there is a custom field for which the display value = true. Even after this, when we lookup for that table through a reference field in another custom table, it is just showing the sys_id field.
I have added field attributes, and with that even the 'search' functionality is working. But, when we lookup to all the records, it is only showing the sys_ids.
What can be the possible reasons for this not working?
sd2097
Hi @all
It got fixed by adding that field using the configure list layout option.
Marking this as accepted solution, in case someone in the future is confused with the same issue.
Ankur Bawiskar
@sd2097
Did you try to create a fresh reference field and see again?
sd2097
Hi @all
