Filter drop down reference field after changing dependency field value
marclindsay
When displaying a Reference Field C as a drop down, how can I get the values to be filtered based on Fields A and B ?
I have 3 Reference fields. Field C values are dependent on what is chosen for Field A and B. I have created a Reference Qualifier to handle the filter for Field C. When changing the values of Field A and/or B, Field C automatically (without pressing Save/Update button) shows the correct new values based on these Fields A and B. All work great, as shown below.
Now if I change Reference Field C to be a drop down.
Now when I change the values for Field A and Field B, Field C (still reference field) does not refresh automatically (without pressing Save/Update button) with a new list of Values.
When displaying a Reference Field C as a drop down, how can I get the values to be filtered / refresh automatically based on values selected for Fields A and B ?
Ankur Bawiskar
I would recommend keeping field C as reference only and not drop down.
Reason being if the table is huge then it won't be a good user experience and user might have to scroll down to select the value.
Also advanced ref qualifier won't work on drop down field as per my understanding.
@marclindsay
Hope you are doing good.
If my response helped please close the thread by marking appropriate response as correct so that it benefits future readers.
Asep
Hi @marclindsay
this post is exacly im looking for but, cannot see attached screenshoot
can you re upload or share the example please? Thanks!
