Flow context still redirects to cancelled flow context -Cancel and Retrigger a Flow through script
Resham Noor
I am trying to cancel an existing flow and attach a new flow using script, which I was able to achieve with below code.
But I am facing an issue with the flow context ui action, when clicked it is still redirecting to the old flow which is cancelled rather than the new flow which is attached.
(function() {
    var grRITM = new GlideRecord('sc_req_item');
    grRITM.addQuery('number', 'RITM0039079'); //Update RITM Number
    grRITM.query();
    if (grRITM.next()) {
        var ritmSysID = grRITM.getUniqueValue();
        gs.print('sourceRecord: ' + ritmSysID);
        gs.print("******************************************");
        var grFlowContext = new GlideRecord("sys_flow_context");
        grFlowContext.addQuery("source_record", ritmSysID);
        grFlowContext.query();
        while (grFlowContext.next()) {
            gs.print("flowContextSysID: " + grFlowContext.getUniqueValue());
            sn_fd.FlowAPI.cancel(grFlowContext.getUniqueValue(), 'Canceling the Flows'); // flow designer name
/*Tried setting Flow context record source field value to blank but still same
             grFlowContext.source_record='';
	     grFlowContext.update();
            //CANCELLING TASK
            var grApproval = new GlideRecord("sysapproval_approver");
            grApproval.addEncodedQuery('state=requested^sysapproval=' + ritmSysID);
            grApproval.query();
            if (grApproval.next()) {
                grApproval.setValue('state', 'not_required');
                grApproval.update();
            /*gs.print("FlowcontextSys_id" + grFlowContext.getUniqueValue());
        (function(ritm_sysID) {
            try {
                var inputs = {};
                inputs['request_item'] = grRITM;
                inputs['table_name'] = 'sc_req_item';
                // GlideRecord of table: sc_req_item
                // Start Asynchronously: Uncomment to run in background.
                var result = sn_fd.FlowAPI.getRunner().flow('global.default_flow').inBackground().withInputs(inputs).run();
            } catch (ex) {
                var message = ex.getMessage();
                gs.error(message);
            var contextId = result.getContextId(); //get flow context sys_id
            var grFC = new GlideRecord('sys_flow_context'); //query the table sys_flow_context using the flow context sys_id to get the sys_flow_context record and populate the fields source_table and source_record
            grFC.addQuery('sys_id', contextId);
            grFC.query();
            while (grFC.next()) {
                grFC.setValue('source_table', 'sc_req_item');
                grFC.setValue('source_record', ritmSysID); //sys_id of the RITM on which you want to start the flow
                grFC.update();
UI action of flow context is OOB and is as below.
function showFlowContext () {
	var url = new GlideURL('catalog_flow_context.do');
	url.addParam('sysparm_sys_id', g_form.getUniqueValue());
	url.addParam('sysparm_ck', g_form.getValue("sysparm_ck"));
	g_navigation.open(url.getURL(), "_blank");
@Ankur Bawiskar @pranavbhagat @Alikutty A
Sandeep Rajput
@Resham Noor
This is bound to happen, as you are cancelling the flow from background script and generating a new one, you also need to update the context value on the RITM record.
On the RITM record there is a field called flow_context
the same field is used when we click on the Flow context UI action in the second parameter.
url.addParam('sysparm_ck', g_form.getValue("sysparm_ck")); //flow_context value from RITM
Since you didn't update this field on the RITM hence it is still taking you to the previous context.
In your code set the value of this field like following
grRITM.setValue('flow_context’, contextId);
grRITM.update();
 Hopefully this will fix your problem and you will be navigated to the correct context.
Glad it helped 🙂
