Flow Designer - Ask for Approval from field by dot walk
Nisha30
Hello Experts,
I am stuck at this point to select Approver from a table .
i have a variable which points to custom Table = u_warehouse
Table = u_warehouse has another field = 'WH Manager'.
In request we need the approval to go to 'WH Manager'' against the data filled in that variable (WH Code)
Example: if LT1 is selected in Variable (WH Code) the Approval should go to Anker Bamah
WH Code                   WH Manager
LT1                              Anker Bamah
BS4                             Amita Sarkel
But in ''Ask for Approval'' there is only option for User, Group,
Please help how to generate this approval step guidance needed please need to avpid as much script if not at all feasible.
Uncle Rob
So you need to do 2 things before the Ask for Approval action.
1)  Get Variables - this will give you access to the wharehouse variable you said is on the catalog item
2)  Look Up Record - (singular not plural) Look up to the wharehouse table where WH Code matches the variable you retrieved in (1)
3)  Ask for Approval - Pull the WH Manager field from (2)
Have you done those steps already?
Hello Uncle Rob,
I am trying to do the same thing however I am able to dot walk to the reference on my custom table.   Is there some ACL I need to add to the table in order for it to read?
Cha
