Flow designer - Data pill values not available in script mode
AEterni
Mega Guru
Hello All,
I have recently discovered that it is not possible to drag and drop data from the data pill values of the flow inside a script.
I hope you can help me with the following requirement.
This is the script we are using
**Access Flow/Action data using the fd_data object. Script must return a value.
**example: var shortDesc = fd_data.trigger.current.short_description;
**return shortDesc;
var pwvalue = new GlideappMaskedQuestion().decode(new GlideEncrypter().decrypt(fd_data._1__get_catalog_variables.password));
var encodedpw = new GlideappMaskedQuestion().decode(new GlideEncrypter("xxx").encrypt(pwvalue));
var output = {"FirmId":46,"EncryptedPassword":encodedpw,"AttachmentId":"b16829cd87d541903c1da6c73cbb350d"};
return output;
I would like to get
  • the "FirmId" from the company table and
  • the sysID of the attachment
For the "FirmId" we usually dot.walk using the data pill values (see image below), but it is not possible when are in script mode.
For the sysID of the attachment, do you know how I can get it?
The final script should look like this one.
**return shortDesc;
var FirmId = xxx
var AttachmentId = xxx
return output;
Thank you.
you want attachment sys_id for the RITM record?
if yes then you need to query sys_attachment with current ritm sys_id
like this
var ritmSysId = fd_data.trigger.request_item.sys_id;
var attachmentID;
var gr = new GlideRecord("sys_attachment");
gr.addQuery("table_sys_id", ritmSysId);
if (gr.next()) {
	attachmentID = gr.getUniqueValue();
return attachmentID;
So your final code when I combined above script is this
var companyID = fd_data.trigger.request_item.company.u_id;
var output = {};
var attachmentID;
if (gr.next()) {
output["FirmId"] = companyID.toString();
output["EncryptedPassword"] = encodedpw.toString();
output["AttachmentId"] = attachmentID.toString();
return output;
Please mark my response as correct and close the thread
16 REPLIES 16
sandeeprawat
I have sometimes encountered similar issue where I am not sure why a certain variable is not accessible in certain variables or loops in flow designer.
If nothing else works, try using flow variable.
It has recently been added to flow designer functionality. Consider it a global variable which you can set and use throughout the flow.
1. Define variable.
2. Set it
Hope it helps.
That's very interesting, but unfortunately it doesn't work.
You can't drag and drop variables and values from the data pill into a script
