Flow Designer - Flow is not getting published
Supriya39
Giga Guru
Hi Team
I have a flow which is not getting published. Below is the error. Is there any way to find out exactly where is issue. The flow is with a lot of steps
Could not publish flow as Action Instance is not published
2 ACCEPTED SOLUTIONS
Supriya39
Giga Guru
In my flow I am using Classification Prediction step for using ML prediction solution. This needed to be published. Earlier when flow had been created there was no need to publish this step but I think we need now.
When I published that action, Flow was getting activated.
Supriya39
Giga Guru
So this was not due to any custom action not published. We have prediction models used in flow. According to new update, we needed those prediction model steps also to be published exclusively which had caused this issue.
14 REPLIES 14
Supriya39
Giga Guru
All actions are published.
Supriya39
Giga Guru
Supriya39
Giga Guru
Dishtiwari
Try to publish via List view if in the Correct application:
adrian08
