Flow Designer: For Each action with Multi Row Variable Set and Select Box
sharvil Sheth1
I have one multi row variable set and it has one variable "Acquisition Method" type is select box with options "Lease" and "Purchase". and user will be edit this variable in catalog task level, not while submitting request, it's hidden while submitting the request.
If "Purchase" is selected then there are few steps, same if "lease" is selected there are other steps.
If I select multi records then also it reflects with first record.
I have achieved this with Flow Action "Look Up Record".
@sharvil Sheth1
so what's your question?
what's not working?
it is checking only 1st record and not the 2nd, it should check both, rather it should iterate through all the records.
@sharvil Sheth1
then use 2 flow variables to check the count of Purchase and Lease and then use Set Flow Variable logic
In the inline script you can parse the JSON from MRVS and then increment the count and then set the flow variables.
Then use IF logic to check the count of each and have your logic
Something like this
I hope I have provided enough information and you can enhance it from here
I tried,
var count = 0;
var mrvs = fd_data._1__get_catalog_variables.add_hardware_models_for_this_request.toString();
var parsedData = JSON.parse(mrvs);
for(var i=0;i<parsedData.length;i++){
if (parsedData[i].acquisition_method == 'purchase')
    count = count + 1;
return count;
but facing with below error
ncountered error executing instruction: OpInstruction{id=42, opClass=com.snc.process_flow.operation.script.InlineScriptOperation, io=Io{input={required_run_time=RefOrValue{value=vanilla, isRef=false}, _1__get_catalog_variables_add_hardware_models_for_this_request=RefOrValue{value=c1o.add_hardware_models_for_this_request, isRef=true}, script=RefOrValue{value=(function (inputs, outputs) {outputs.__...
@sharvil Sheth1
did you add logs and see?
try this
var count = 0;
gs.info('json is' + mrvs);
if (parsedData[i].acquisition_method.toString() == 'purchase')
    count = count + 1;
return count;
Did you include that MRVS variable set in the Right side of bucket in "Get Catalog Variables"
are you using correct mrvs variable set name?
are you using correct variable name present within MRVS?
are you using correct value to compare?
