Flow Designer: For Each action with Multi Row Variable Set and Select Box
sharvil Sheth1
I have one multi row variable set and it has one variable "Acquisition Method" type is select box with options "Lease" and "Purchase". and user will be edit this variable in catalog task level, not while submitting request, it's hidden while submitting the request.
If "Purchase" is selected then there are few steps, same if "lease" is selected there are other steps.
If I select multi records then also it reflects with first record.
I have achieved this with Flow Action "Look Up Record".
