Flow designer if condition help
RudhraKAM
Hello There
I have a requirement where the flow is triggered ,when the RITM is created , in a section we need to check if the user provided value in a string variable is "Pedcs" or "Rad Onco" we have 200 like this , what is the best way to add these , so that we can maintain
Yes you ca try with comma separated but custom action will provide more flexibility
Hello @RudhraKAM
I do not think the config you showing in PIC will work as it is checking contains. Means it will check if the variable value contains entire value you are providing in that next field.
Thank you,
Ali
