Flow designer - In flow context steps not running in UI but records updating
‎08-27-2026 01:07 AM
When i tried testing a flow , In flow context only first 7,8 steps are showing as running on flow context UI. I cant open any subflows or action outputs and logs from UI . But the subflows and actions are running and updating the specified values in records . Because of this i cant debug the flow correctly .
#flowdesigner #flowcontext #flowtesting #flowcontextui #flowstepmapping
‎08-27-2026 01:09 AM
@Ankur Bawiskar Please help 🙂
‎08-27-2026 01:16 AM
Hi @irfan_fedserv ,
do you see any message on the flow context?, Have you enabled flow logging on this flow? if not please enable it full (Since Australia version, global property which controls flow logging will not work)
Please test this sub prod, enable it in prod, you can disable once debugging is done!
Hope it helps!
Thank you,
Hemanth
Certified Technical Architect (CTA), ServiceNow MVP 2024, 2025,2026
‎08-27-2026 01:42 AM
flow is in waiting state and when i open flow logs there is nothing .
when i open flow context backend table the subflow is completed ,
but in main flow it doesnt even enter this step .(step 9). In flow any other step is not running in UI . But the values are updating
‎08-27-2026 01:30 AM
Hi @Hemanth M , Thank you for the reply .
Flow reporting is set as system default .
where can i turn on the flow logging?
