Flow does not create the Catalog task for non admins
Danny Barker
We had a new hire flow built out and upon testing, we discover that the catalog task are only creating for our admins.  I have impersonated other users to verify the request is just stopping at the RITM.  I gave a user admin role and confirmed we now get Catalog tasks.  I did verify the New hire flow is published.
I have built other flows that are functioning and didn't come across anything that was to make catalog task only trigger for admin.
Any help would be much appreciated.
3 ACCEPTED SOLUTIONS
Sagar Pagar
Hi @Danny Barker,
Run as user should be System user.
If my response helps you resolve your issue. Kindly mark it as helpful & correct. It will be helpful to future readers! 👍🏻
Sagar Pagar
The world works with ServiceNow
Ankur Bawiskar
@Danny Barker
Please use Run as System User as mentioned by others and then verify
Hello @Danny Barker ,
Yes you need to set Run as "system user" for all the subflows then only it will execute flow and subflows as system and won't check login user roles and permissions
If my response is useful, then kindly mark it as "Accept as Solution" and " Helpful."
14 REPLIES 14
Thanks Tera, I did see that it was set to Run as " User who initiates the session". I changed it to run as " System User".  I tested by impersonating someone non admin and still do not see the catalog tasks.
After changing Run as system user. Have you published the flow?
Danny Barker
I went into the flow and checked Executions.  I see the Error for a non admin that shows it to be under "Open Subflow Context".  Would it be that I need to set all the subflows to also " Run as System User"?
siva krishna M2
