Help in Scripting if(gr.next()) is not working
priya149
Mega Contributor
After madrid upgrade this script is not working in prod, the same is working in kingston.
Below code is displaying description of incident on approval request in portal but description is not getting visible after madrid upgrade only for incident.
kindly guide if anything wrong in it.
if (record.source_table == 'incident') {
gs.log("Madrid Changes hello");
inc.addQuery('sys_id', record.sysapproval.sys_id.toString());
gs.log("Madrid Changes variable" + record.sysapproval.sys_id.toString());
inc.query();
if (inc.next())
gs.log("Madrid changes dsc" + inc.description.toString());
ticket.description = inc.description.toString();
ticket.comment_approval = 'true';
Logs are not coming inside if (inc.next()) and if I remove the IF condition value is not coming in  inc.description.toString();
In sort inc.description.toString(); is not working as well.
25 REPLIES 25
Because we are displaying incident description on portal for approver to approve incident
Yes, but  record.sysapproval.sys_id.toString() returning incident record or approver record?
Can you print the value of this record.sysapproval.sys_id.toString() and then go to incident.list and filter by sys_id and put this value and check if you are getting the record or not.
Mark the comment as a correct answer and also helpful once worked.
Hi Priya,
Is the issue resolved? If not, kindly follow the steps once that i have mentioned above.
hvrdhn88
Giga Patron
the best way to check the rowCount() of your second glide record , might be possible the addQuery() filter is not working. .
Updated script with logs.  try to run and let me know the log details.
if(record.source_table == 'incident') {
inc.addQuery('sys_id', record.sysapproval);
gs.log("Madrid Changes variable" + record.sysapproval);
inc.query();
gs.log('Row Count is'+ inc.getRowCount());
if (inc.next())
ticket.description = inc.description;
Result -
Madrid Changes variable5f1f9d2fdb217b40c4759ef7db96196f
Row Count is0
