Help with building a Relationship to query RITM variables
Steve8
I am trying to reuse some code I found on another post for building relationships. I am still learning scripting. But I fear trying to query off RITM variables is tossing me for a loop and I could use some help. My goal is to build a related list for my facility table to show all request items that have the facility selected in the RITM's variable field site_location_1 or site_location_2. Ideally I dont want to have to define the catalog item specifically, because I have many catalog items that use this field name. But if I do, would need to build an array of cata item names.
(function refineQuery(current, parent) {
	// Add your code here, such as current.addQuery(field, value);
	var ritms = [];
	gr.addQuery('cat_item.variables.site_location_1',parent.sys_id);
	gr.addQuery('cat_item.variables.site_location_2',parent.sys_id);
	while(gr.next())
		ritms.push(gr.getValue('sys_id'));
	current.addEncodedQuery(ritms);
})(current, parent);
Steve8
I played around with the code some and got this working. Thank you for the help!
	var ritms = [];
	while (gr.next()) {
		var siteLoc1 = gr.variables.site_location_1;
		var siteLoc2 = gr.variables.site_location_2;
		if (siteLoc1 == parent.getValue('sys_id') || siteLoc2 == parent.getValue('sys_id')) {
	current.addQuery('sys_id', ritms);
Thanks for the update, Steve. Would you mind marking my response as helpful/correct if I am able to resolve your query? thanks
- Pradeep Sharma
