Help with calling a Workflow from the flow designer
muktha1
Hi all,
I have created a catalog request item and want to attach a flow designer with approval action, Emails and an orchestration flow of adding computer to AD group. I created an  orchestration workflow on the requested item table but unable to call it from the flow designer . I read in the community that workflows running on requested items table will not be visible in the Call a workflow list. If that is the case , how do I create the orchestration workflow outside of the requested item table and call it it the flow designer? Can anyone please suggest?
using script as I mentioned in my earlier link using custom action
create custom action
Custom Action in ServiceNow Flow Designer
then use script from below link where I shared solution to trigger the workflow
workflow from script with example
11 REPLIES 11
you can use Script action in flow designer and invoke the workflow using that and pass the ritm variable value to it
@muktha
Hope you are doing good.
If so, please mark appropriate response as correct & helpful so that the question will appear as resolved for others who may have a similar question in the future.
Thanks!
@muktha
Thanks!
Hi Ankur,
How do I invoke a workflow from the flow designer ? Workflow built on RITM not visible in the list. How else should I invoke a  workflow which will involve adding computer to an AD group?
