02-26-2021 12:42 AM
Hi all,
I have created a catalog request item and want to attach a flow designer with approval action, Emails and an orchestration flow of adding computer to AD group. I created an orchestration workflow on the requested item table but unable to call it from the flow designer . I read in the community that workflows running on requested items table will not be visible in the Call a workflow list. If that is the case , how do I create the orchestration workflow outside of the requested item table and call it it the flow designer? Can anyone please suggest?
03-02-2021 05:29 AM
using script as I mentioned in my earlier link using custom action
create custom action
Custom Action in ServiceNow Flow Designer
then use script from below link where I shared solution to trigger the workflow
workflow from script with example
03-11-2021 02:24 AM
Hi Ankur,
The requirement was urgent .Hence I created a workflow and a sub workflow for adding computer to AD group and completed the process as I was not able to achieve it with my limited knowledge in flow designer.
I would like to follow your suggestions and try it out in flow designer once again.
Muktha
03-11-2021 02:31 AM
Glad to know.
Would you mind marking the best matching answer as correct and helpful, to close this thread?
