Help with Flow Designer input variable script for getting current date and adding days to it
jlaue
Hello -
I am trying to get a script to work in a Flow Designer flow, input variable.  I just want to get the current date in the script and then add 60 days to it and return that value, however it keeps returning a null value.
Here is what I have for the script:
var date = new GlideDate();
var review = date.addDays(60);
return review;
Also tried just new Date();
Not sure if this script is wrong or if it just isn't formatted properly to work within Flow Designer.
Thanks!
Hi @jlaue ,
I think you should use GlideDateTime in these type of scenarios.
Snippet should be something like this-
(function() {
    var gdt = new GlideDateTime();
    gdt.addDaysLocalTime(60);
    return gdt.getDate().toString();
brianlan25
Are you creating a scripted action for this? If not were are you putting the script in flow designer?
Sheldon  Swift
Hi @jlaue - What are you doing with the date? You can return a string like this:
// Create an instance of GlideDateTime to get the current date and time
// Add 60 days to the current date
gdt.addDays(60);
// Format the date
var date = gdt.getDate();
gs.info(date.getByFormat('dd/MM/yyyy'));
Hi @jlaue ,
(function() {
Thanks for the quick help!!   I was able to utilize that script to get it to work:
