03-03-2026 02:03 PM
I have a requirement to have a modal on load to present a message to the requester when they load a catalog item.
Most times they are likely going to select the positive option and want to proceed, however I need to cover the chance that they don't want to proceed. So I want to take them back to either their previous page or to a set url if they cancel.
We are on Zurich and this is on Employee Centre
Below is what I currently have in a catalog client script.
Applies to - A Catalog Item
Active is true
UI Type - ALL
Type - onLoad
Applies on Catalog Item view - True
function onLoad() {
if (typeof spModal !== 'undefined') {
if (g_scratchpad.isFormValid) {
return true;
var actionName = g_form.getActionName();
spModal.open({
backdrop: 'static',
keyboard: false,
message: 'Please select cancel if you want to go back',
title: 'This is a test',
buttons: [{
label: 'Cancel',
cancel: true
label: 'Proceed',
primary: true
}).then(
function onAgree(result) {
g_scratchpad.isFormValid = true;
g_form.submit(actionName);
return true;
function onDisagree(reason) {
setTimeout(function() {
window.location.href = 'https://www.testing.com';
}, 0);
return false;
g_scratchpad.isFormValid = false;
return false;
var gm = new GlideModal();
gm.setTitle('Error');
gm.renderWithContent('Something has gone wrong Prompt');
Would love some help please.
03-03-2026 08:08 PM
then try this and it will work in portal
function onLoad() {
var modalInstance;
spModal.open({
buttons: [{
label: 'Proceed',
value: 'agree',
primary: true // Makes this button visually prominent
label: 'Cancel',
value: 'disagree'
}).then(function(result) {
// This function executes when a button is clicked
if (!result.primary) {
top.location.href = 'https://www.testing.com';
if (modalInstance) {
modalInstance.dismiss(); // Dismisses the modal
03-03-2026 07:45 PM
You have to set isolate script to false, then you can access the window object from this.
function onLoad() {
return true;
spModal.open({
backdrop: 'static',
keyboard: false,
buttons: [{
label: 'Cancel',
cancel: true
label: 'Proceed',
primary: true
}).then(
g_form.submit();
return true;
this.location.href = 'https://www.testing.com';
}, 0);
return false;
return false;
}To successfully submit with gform on the catalog item widget you also need to do something like this. Make sure you dont have two step checkout on the item
const $scope = angular.element("#sc_cat_item").scope()
$scope.data.sc_cat_item.item_action = "order";
g_form.submit()
//or maybe instead of submit use
$scope.triggerOnSubmit()
03-03-2026 08:14 PM
@l457 thank you for your help, I appreciate your reply
I could not however isolate the script as that option was no available on an onload script.
We don't have two step checkout enabled at all
03-03-2026 09:00 PM
Isolate script can be used for all client scripts, but I didn't realise that it actually doesn't stop accessing top as shown in Ankurs solution.
The two step checkout would have mattered only if you needed the g_form.submit() call but it doesn't seem like you actually wanted that
