Help with Ritm
Abhijit Das7
Hi Everyone,
I have created a catalog item where in "Process Engine" I have chosen Execution Plan as Default. But when I am testing that catalog item then in RITM, "Stage" field is displaying as "nothing".
I have created before  business rule (update) on RITM table, with a conditon  when catalog item is my catalog item then ritm should be assigned to specifically to a particular group.
Can someone suggest how can I solve this issue.
Thanks in advance
@Abhijit Das7 Can you verify if flow/workflow field is populated on your catalog item?
Workflow/flow is needed to populate the stage field.
