Help with Script Include to get Roles Based on Group and User
patricial
Ok I need some help please!
I am jammed up with getting this to work.
I have a catItem that adds a user to Group
I need to first check what roles the group has
Check what roles the user has
If the group has itil and the user has itil = success
If the group has appover_user and user has approver_user = success
If group has itil and user does not have itil = fail
If group has approver_user and user does not have approver user = fail
If group does not have either itil or approver_user = success (regardless of what roles user has)
Here is my script Include (My client script follows) in my client script I need to return a message based on which role the user failed on
So if the user does not have ITIL (User does not have ITIL message)
If the user does not have approver_user (User does not have approver_user message)
/******* script include *********/
var getRolesAjax = Class.create();
getRolesAjax.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getRole: function(){
gs.log('>>>DEBUG: returnGroup Role() started...');
var list = [];
var grp = this.getParameter('sysparm_group');
gs.log(grp,'shipra0');
var grGroup = new GlideRecord('sys_group_has_role');
grGroup.addQuery('group', grp);
grGroup.addQuery('role.name', 'itil');//itil
grGroup.query();
while(!grGroup.next()){
//var rol = grGroup.role.getDisplayValue(); //group itil
//return 'success';
//continue;
var gr2Group = new GlideRecord('sys_group_has_role');
gr2Group.addQuery('group', grp);
gr2Group.addQuery('role.name', 'approver_user');//approver user
gr2Group.query();
while(!gr2Group.next()){
//var rol2 = gr2Group.role.getDisplayValue(); //group approver_user
//gs.log('>>>TRICIA Query GROUP APPROVER:' +urol);
return 'success';
//continue;
var usr = this.getParameter('sysparm_requestedby');
var grUser = new GlideRecord('sys_user_has_role');
grUser.addQuery('user', usr);
grUser.addQuery('role.name', rol); //itil from group
grUser.query();
while (grUser.next()) {
var urol = grUser.role.getDisplayValue(); //itil role
var usr2 = this.getParameter('sysparm_requestedby');
var gr2User = new GlideRecord('sys_user_has_role');
gr2User.addQuery('user', usr);
gr2User.addQuery('role.name', rol2); //approver_user role
gr2User.query();
while (gr2User.next()) {
var urol2 = gr2User.role.getDisplayValue(); //approver user
gs.log('>>>TRICIA Query USER ITIL:'+rol + " " +urol);
if(rol == urol || rol == ''){
continue;
//return 'success';
if(rol2 == urol2 || rol2 == ''){
gs.log('>>>TRICIA Query for USER APPROVER:'+rol2 + " " +urol2);
return 'success';
type: 'getRolesAjax'
/*******Client Script*********/
g_form.setValue('no_license', 'false');
g_form.setValue('request_license', 'No');
var grp = g_form.getValue('group_name');
var usr = g_form.getValue('requested_by');
alert('Calling getRole... ' + grp);
var ga = new GlideAjax('getRolesAjax');
ga.addParam('sysparm_name','getRole');
ga.addParam('sysparm_group', grp);
ga.addParam('sysparm_requestedby', usr);
ga.getXML(AsyncCall);
function AsyncCall(response) {
if (answer == 'success') {
g_form.setValue('request_license', 'Yes');
alert(answer);
else{
g_form.addInfoMessage('ITIL Role is required for Group Access.');
g_form.setValue('no_license', 'true');
Please check if this helps..
Script Include:
var isITIL, isAPUSER, isANYGRPROLE;
grGroup.addQuery('group', this.getParameter('sysparm_group'));
grGroup.query();
while(grGroup.next()){
grUser.addQuery('user', this.getParameter('sysparm_requestedby'));
if((grGroup.getDisplayValue('role') == 'itil')){
grUser.addQuery('role', grGroup.getValue('role'));
grUser.query();
if(grUser.next()){
if((grUser.getDisplayValue('role') == 'itil')){
gs.log('isITIL = true');
isITIL = true;
else
isITIL = false;
if((grGroup.getDisplayValue('role') == 'approver_user')){
grUser.query();
if(grUser.next()){
if((grUser.getDisplayValue('role') == 'approver_user')){
gs.log('isAPUSER = true');
isAPUSER = true;
else
isAPUSER = false;
if(grGroup.getDisplayValue('role') != 'approver_user' && grGroup.getDisplayValue('role') != 'itil')
isANYGRPROLE = true;
if(isITIL == true || isAPUSER == true || isANYGRPROLE == true)
return 'Success';
else if(isITIL == false && isAPUSER == false)
return 'Approver User and ITIL Role is required for Group Access.';
else if(isITIL == false || isAPUSER == false)
if(isITIL == false)
return 'ITIL Role is required for Group Access.';
else if(isAPUSER == false)
return 'Approver User Role is required for Group Access.';
Client Script:
ga.addParam('sysparm_group', g_form.getValue('assignment_group'));
ga.addParam('sysparm_requestedby', g_form.getValue('requested_by'));
g_form.addInfoMessage(answer);
14 REPLIES 14
Hi Patricia,
Can you please mark my answer correct, if i was able to help you.
Script Include:
grGroup.query();
grUser.query();
if(grUser.next()){
isITIL = true;
else
isITIL = false;
grUser.query();
if(grUser.next()){
isAPUSER = true;
else
isAPUSER = false;
return 'Success';
if(isITIL == false)
Client Script:
Thank you so much Shishir!!!!! 🙂
I will try this out for the messages!
I really really appreciate all your help!
Tricia
Thank you Shishir!!!
I got everything working:-)
You're the best!!
Tricia
Shishir,
I almost figured out returning the custom message with json,
I added the   following in the script include after the isANYGRPROLE = true
and the below in my client script
I dont think I have the script include json correct
So I want a custom message based on if they need the itil role or if they need the approver+user role, or if they need both
If I can get one to work I should be good with the others
any idea what I am doing wrong?
Thank you
else if(grGroup.getDisplayValue('role') != 'approver_user' || grGroup.getDisplayValue('role') != 'itil'){
else if(grGroup.getDisplayValue('role') == 'itil'){
if(isITIL == false){
var retNoItilRole = {};
retNoItilRole = 'ITIL role license required for access to this Group';
return new global.JSON().encode(retNoItilRole);
And then added this to the client script to test
answer = answer.evalJSON(); //Transform the JSON string to an object
