11-13-2017 12:31 PM
Greetings all. I'm still learning my way around Glide Ajax and know there's probably a very simple mistake in my code here but I can't see it. All I want to do is update 2 variables (location and department ) on my form when the requested for person changes.
Here's my Script Include named getRequestedForData:
var getRequestedForData = Class.create();
getRequestedForData.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getUserData: function() {
try {
var userId = this.getParameter('sysparm_id');
var result = this.newItem('result');
var array = [];
gr.addQuery('sys_id', this.getParameter('sysparm_id'));
while(gr.next()) {
var object = {};
object.id = gr.getUniqueValue();
object.loc = gr.getValue('location.name');
object.dept = gr.getValue('department.name');
array.push(object);
var json = new JSON();
var data = json.encode(array);
return data;
catch(e) {
gs.log("CDL: E- " + e.message);
type: 'getRequestedForData'
And here's my Catalog Client Script, (OnChange based on the requeste_for variable):
if (newValue == '') {
g_form.setValue('iops_brm_location', '');
g_form.setVisable('iops_brm_location',false);
g_form.setValue('iops_brm_department', '');
g_form.setVisible('iops_brm_department',false);
//get Requested For Data
var ga = new GlideAjax("getRequestedForData");
ga.addParam('sysparm_name','getUserData');
ga.addParam("sysparm_id",g_form.getValue('requested_for'));
confirm("ReqFor: GA Started");
ga.getXML(setReqForDetails);
function setReqForDetails(response){
try{
answer = answer.evalJSON();
catch(e){
answer = JSON.parse(answer);
g_form.setValue('iops_brm_location', answer.loc);
g_form.setReadOnly('iops_brm_location',true);
g_form.setVisable('iops_brm_location',true);
g_form.setValue('iops_brm_department', answer.dept);
g_form.setReadOnly('iops_brm_department',true);
g_form.setVisable('iops_brm_department',true);
Scripting and Coding
11-17-2017 02:04 PM
I managed to find the solution. I was using an array for no good reason which complicated things. I removed the array and updated the script include.
Old, non-working, Script Include:
try {
var array = [];
while(gr.next()) {
var object = {};
array.push(object);
return data;
catch(e) {
New, working, Script Include:
getUserData: function(name) {
var iopsSysId = this.getParameter('sysparm_id');
gr.addQuery("sys_id", iopsSysId);
if (gr.next()) {
var ga = {};
ga.id = gr.sys_id + '';
ga.loc = gr.location.name + '';
ga.dept = gr.department.name + '';
ga = json.encode(ga);
return ga;
11-16-2017 08:02 PM
Please check if below changes helps,
in Client Script:
try{
In script Include:
object.loc = gr.getDisplayValue('location');
object.dept = gr.getDisplayValue('department');
11-16-2017 09:18 PM
HI Conan,
Can you tell me where are you working on this code i.e. Service portal or ESS.
Thank you,
Ashutosh
11-17-2017 02:04 PM
try {
var array = [];
while(gr.next()) {
var object = {};
array.push(object);
return data;
catch(e) {
if (gr.next()) {
var ga = {};
return ga;
