Help with Workflow script = forEach
Lon Landry4
I can get the script below to work for a single record without any of the forEach function lines below...
But, I must be so missing something when trying to loop through this array (mrvsValues).
Any suggestions?
var mrvsValues = current.variables.mrvs_sys_ids;
gs.info("payload = "+ mrvsValues);
mrvsValues.forEach(function (value){
var payloadParsed = JSON.parse(mrvsValues); //this gets my input readable
gs.info('Parsed: '+payloadParsed);
var grAsset = new GlideRecord('alm_hardware');
grAsset.addQuery('sys_id', payloadParsed);
grAsset.query();
if (grAsset.next()){
grAsset.install_status = '6';
grAsset.update();
SanjivMeher
Mega Patron
I think you are suppose to parse it to JSON before the loop. Also can you try the for loop?
for(var i in payloadParsed)
gs.info('Parsed: '+payloadParsed[i]);
grAsset.addQuery('sys_id', payloadParsed[i]);
grAsset.query();
grAsset.update();
AniketC85155510
Hello @Lon Landry4
You can refer to the below script and give a shot.
gs.info("payload = " + mrvsValues);
mrvsValues.forEach(function (value) {
  var payloadParsed = JSON.parse(value); // Parse each element of the array
  gs.info('Parsed: ' + payloadParsed);
  grAsset.query();
  if (grAsset.next()) {
    grAsset.upda
te();
Please let me know your views on this and mark helpful and correct if it's helpful to you.
Thank you,
Aniket
Ethan Davies
I think the issue is with how you are handling the payload for the MVRS. The payload for a Multi-Row Variable Set is an Array of Objects, so you need to treat it as such. Each row in the Multi-Row Variable Set is represented as a single Object in the Array. So if you have 3 rows, there will be three Objects in there. For each of the Objects, there are key-value pairs that represent the MVRS field name and value.
With all that said - your code will need to look something like this.
for (var row in payloadParsed) {
    // Replace 'element' with the name of the field in your MVRS that contains the sys_id of the asset record you want to update.
    updateAsset(payloadParsed[row].element);
function updateAsset(assetID) {
    if (grAsset.get(String(assetID))){
        grAsset.update();
You could also make the code above more efficient by just making one GlideRecord call instead of multiple.
var idsToUpate = [];
    idsToUpate.push(payloadParsed[row].element);
updateAssets(idsToUpate.toString());
function updateAssets(assetIDs) {
    grAsset.addEncodedQuery('sys_idIN'+assetIDs);
    if (grAsset.hasNext()){
        grAsset.updateMultiple();
