Help with writeBase64 in GlideSysAttachment
Abhijit Das7
Hi Everyone,
I am trying to send base64 image as attachment to sys_cs_collab_chat table using GlideSysAttachment , but it not attaching and not even returning any error.
Scripted Rest API:
(function process( /*RESTAPIRequest*/ request, /*RESTAPIResponse*/ response) {
    // implement resource here
    var requestBody = request.body.dataString;
    var parser = new global.JSON();
    var parsedData = parser.decode(requestBody);
    var imageName = parsedData.imageName;
    var imageType = "image/jpeg";
    var imageValue = parsedData.imageValue;
    var table = parsedData.object_name;
    var sysId = parsedData.object_id;
    var rec = new GlideRecord(table);
    rec.addQuery('sys_id', sysId);
    rec.query();
    if (rec.next()) {
        if (imageName && imageValue && imageType != '') {
            var sa = new GlideSysAttachment();
            sa.writeBase64(rec, imageName, imageType, imageValue);
})(request, response);
JSON payload;
{"object_id":"ea09239a97d00290c0ebd404a253af08",
"imageName":"QjjeAKNbCwNoJwEKrg1dObUx.jpg",
"imageValue":"<<base64FileContent>>",
"object_name":"sys_cs_collab_chat"}
Can anyone point out my mistake.
cc: @Ankur Bawiskar
Thanks in advance.
12 REPLIES 12
@Abhijit Das7
did you check in sys_attachment it came fine?
When you download the image from sys_attachment is it a proper one or a corrupted one?
Hi @Ankur Bawiskar,
yes, it came fine sys_attachment. I am able to download and I can see it. It is fine.
@Abhijit Das7
then definitely it's something when you view it in sidebar
can you share screenshot where are you willing to see this?
Hi @Ankur Bawiskar
I want the image(attachment) to be visible in sidebar chat as it is there in below image. But that image I have added manually.
I want to make image(attachment) using Scripted Rest API inside sidebar chat. I am able to send text inside sidebar chat using Scripted Rest API, but image is not coming
@Abhijit Das7
possibly it won't be direct.
Did you check when you add image manually how it's stored?
