Hide Insert and Insert and Stay UI Actions
brianlan25
I have a custom table and I need to hide the right click options for Insert, Insert and stay.  I took the global UI actions for insert and stay and insert put them in my custom table then unchecked active but they are still showing.  Is there something else I need to do?
Ok that worked putting false in the condition but leaving active as true.  Never had to do that before.
11 REPLIES 11
Definitely interesting. @dvp is that for UI actions you found that to be a commonality?
Also Brian, if you don't mind, can you mark dvp answer as correct if they helped get you there to your solution?
Thanks!
Is that for UI actions you found that to be a commonality?
You can use it in any of the script fields, but I don't see a use case other than the UI actions where we need to keep the UI action active but shouldn't display the button.
